Ca18det Wiring Info
90_240sx_CA18
Car: 95 200sx SE-R, 95 20sx SE-R, 90 240sx CA18, 91 180sx SR20
Hi everyone, i new to the forums. i was just wondering if anyone new where i could find info on wiring in the CA18det harness. I have a 90 240sx. I'm sure lots of you have done this before so any info would help alot. Please let me know so i can finish my swap. thanks.
teddy
Car: Saab Turbo and MR2
Heavythrottle.com has a writeup for the sr wiring, which is almost identical to ours. Or you could send it off to someone and have them do it. Check the sticky's up top, theres quite a bit of wiring info there.
oversteer180
Car: 1990 Silver 240sx
th ca and sr wiring processes are the exact same. check on heavy throttle and follow that exactly, if you need more help, hit me up on aim. azlehornetrunner
90_240sx_CA18
Hey thanks for the info. I'll check it out and for any reason i have question i'll keep you in mind. also i have a buddy of mine that has a 89 240sx. wants to go with the same setup as me but his is an Automatic and idea i how to make the five speed conversion? What is needed? Thanks!
90_240sx_CA18
forget about the Auto swap question i just found it on Heavythrottle.com Thanks tho!
oversteer180
i can also asist you throught the 5 speed swap proccess, as i have ahd to do it in 3 of my cars
90_240sx_CA18
Hey man, sounds great. Please assit me in the process so i can help my buddy out. How long is the process? I really appriciate your help.
90_240sx_CA18
I had another question does the CA18 ECU fit onto the KA ECU adapter? How can you tell the Difference between the CA harness and the KA harness?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
90_240sx_CA18 wrote:I had another question does the CA18 ECU fit onto the KA ECU adapter? How can you tell the Difference between the CA harness and the KA harness?
No it does not fit. The CA plug is specific. And you can tell the difference because the CA harness has the AC plug on it in addition to totally different plugs for the various components.
90_240sx_CA18
What wires are the ones that need to be extended in the ca18det harness? And what part of the kA harness will i be needing? Any help aould really help. thanks
Akihisa
Car: 300zx, Italjet Formula 50Lc, Italjet Dragster 180
Some of the wires that come off the ca harness at the ecu. They might have a plug, might not. YOU NEED TO USE THE plug in the same place from the KA harness. Lengthen those wires if you cut it to short on the connector from the ka harness and get your soldering going. most colors are the sam and some aren't.
oversteer180
maf and power steering wires need to be extended.
c-rad
oversteer180 wrote:maf and power steering wires need to be extended.
Power steering wires? Uhh....
