CA18det wireing into 89 s13
aaronscomp
Car: s13
ok im thinking about ordering a CA from Nagasaki motors but for the wiring is there any write ups on how to wire it up into a 89 s13.
drifting circles
Car: 240sx
first off its wiring. It pretty much the same as a Sr20. I think its frsport.com that has everything you need.
zmannz
Car: 89 s13 coupe- track car
92 s13 coupe- dd
Search?
slo
Car: S13
aaronscomp wrote:ok im thinking about ordering a CA from Nagasaki motors but for the wiring is there any write ups on how to wire it up into a 89 s13.
oooo, i heard bad things about that company... good luck!
aaronscomp
Car: s13
what company do you recommend then
drifting circles
Car: 240sx
Venus Auto or jhot.
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
try Japanese Star Motor too. Very good people. for wiring, hit up heavythrottle's write-up on the SR20. Its good crap
eastslider
Car: 240sx with a ca18det
you can get the sr20det wire harness guide from here http://www.frsport.com/SR20DET....html and it is the same for a ca18. and i wired up my ca this way and it is cherry. u just need to hook up the knock sensor to the white wire that is a little bigger than the smallest wire by the clips. where u cut and splice unless u use the ca18det bottom harness but i just used the ka one u just need to change like 2 plugs on it then the rest is direct fit.
