ca18det water pump
shane_lxi
Car: '71 Datsun 521, '89 240sx coupe, '90 240sx fb, and 2 s13 shells
Don't say it, did a search already, lol. I ordered an '86 200sx ca18et water pump to replace the leaky one on my ca18det engine. It won't bolt up though. All the holes are in the wrong place. Did I order the right part? Or did they just send me the wrong part? I'd like to know though, because it will be another week to get a replacement, and if it going to be the wrong part anyway, then I'm out a car for taht long (I'll have to keep driving my pos datsun :P, lol)
boost_boy
shane_lxi wrote:Don't say it, did a search already, lol. I ordered an '86 200sx ca18et water pump to replace the leaky one on my ca18det engine. It won't bolt up though. All the holes are in the wrong place. Did I order the right part? Or did they just send me the wrong part? I'd like to know though, because it will be another week to get a replacement, and if it going to be the wrong part anyway, then I'm out a car for taht long (I'll have to keep driving my pos datsun :P, lol)
They gave you the wrong pump. The CA18ET is a CA18 (block code) no change in water pump design.
Dee
shane_lxi
Thank you very much. I know the fwd ca18de water pumps won't work (or so I was told) so I knew there should be something here in the states that would.
MegasquirtCA
Car: 240sx
Actually they do work, you just need the FWD water pump pulley as the inner hole is smaller.
They probably gave you a CA20E water pump or possibly a VG30E
boost_boy
shane_lxi wrote:Thank you very much. I know the fwd ca18de water pumps won't work (or so I was told) so I knew there should be something here in the states that would.
THe FWD pumps will work, but you'll have to use a fwd pulley and you can't use your fan clutch on this pump or it will sheer itself in half because it wasn't designed to carry the weight nor the force of the fan blade and clutch.
Dee
shane_lxi
interesting, and good to know.
zil40
Car: 89 240sx
so i made a mistake and bought a ca18de water pump because thats what i thought i needed but after that reading this thread i found out i was wrong i see that i can still use it but need the de pully will everything line up and will and it isnt going to break i just have to use a electric fans if you guys can help thanx
