CA18DET Vert Swap - Spectator View!
trevr
Car: '07 Mitsubishi Eclipse V6 swapped supercharged
'93 Nissan 240SX Vert CA18det **SOLD**
turbo-sil40 wrote:thanks mans hopefully it will work out so i can reinstall my top mount too.
Here is a quick pic of the WG adapter. I won't be installing this until the outlet pipe and front pipe is installed though, but it looks like it will give the dump pipe the right angle as of now
trevr
Made some progress on the swap today. First thing out of the way was plugging up the water port on the block. I've ask for support and ideas in another thread which helped me through it, and I can now scratch it from the list of things to do.
zer...moval
I still wasn't comfortable with how close the master brake cylinder was to the turbo. So while the manifold and turbo out of the car, I decided to swap the smaller brake booster from the '91 Fastback to give more clearance.
Top view of original booster
Vert on the left, Fastback on the right.
Installed
Now that's much more comfortable
Here is how close it used to be. Now its pulled closer to the firewall, and up a ways more.
At about this point, I ran out of daylight... All next week isn't looking too good with rain and snow in the forcast, so work continues next sunny warm day.
turbo-sil40
Car: 00' Land Rover Discovery, 1990 nissan silvia conversion coupe with CA turbo swap
so the dump pipe you are using will work with this adaptor, sweet. Where did you get the dump pipe from I need to get both of those the adaptor and the dump pipe. Maybe to make things easier you can email me your number so I can call you up to talk, I think it will be easier my email is [email protected] If I could call you up that would be awsome I have some more questions thanks man.
