rotorific wrote:So my next question is the difficulty of replaceing them? I mean I've done alot of external motor work (swaps etc.) but when It comes to replacing internal parts I start getting woozy. I was looking at the pictures of davids rebuild Thread and it appears you really can't get to them without taking the head off??
Any help or suggestions on special tools would be appreciated.
-Gabe
Even though i didnt do them myself, i dont think its too hard. If you find the right tool(s) for the job, im sure it would make it that much easier! I took it to a rebuild shop and they did it for me along with a few other things. The thing that makes it hard is the fact that you have to remove literally all parts of the valvetrain. This means cam covers, caps, hydraulic lifter, keepers, retainer, spring, and then the valve. Theres one other flat washer on the opposite side of the spring where the retainer goes. The stem seal will be at the bottom and theres gotta be a tool that goes in there and grabs it from the sides. Its very tight in there so i couldnt see how it could be done by hand.
Heres a link to a pretty damn good walkthrough of a valve stem seal job. It shows the special tools that were used too. Its not a CA specific, its from a Ford Taurus SHO but gives you a good idea of what to expect, with the heads on! Also part of the valvetrain of this engine is very similar to the CA's.
http://www.shophoenixproject.c...s.htm
