CA18DET valve stem seals
Ca_Silvia
I did search this site and other but i couldn't find any info on where to find ca18det valve stem seals, anyone know where i could find them?
jt15833
Car: 95' 240SX
probably from nissan if you say you have an 88 pulsar nx se, as most motor parts will cross over, im not 100% sure about valve stem seals though
Akihisa
Car: 300zx, Italjet Formula 50Lc, Italjet Dragster 180
The valve seals from nissan are real expensive. You can get a head rebuild kit from Advance auto parts for less and it comes with the seals.
jt15833
Car: 95' 240SX
your call if you wanna go genuine oem or autoparts store, for a part that requires alot of labor to get too and should be of exceptional quality i know the route id take
iliketocrash
i've replaced valvestem seals with a kit i got from autozone and they hold up fine. and i know i'm no mechanic but just by looking at the seals and replacing them, it doesn't seem like there is a whole lot to 'em so they'd be kinda hard to f up. sorta like a gasket.
jt15833
Car: 95' 240SX
yea its not like 100% of auto parts stores parts are going to be defected/break early but for a part that you have to do that much work for id pay extra for ease of mind that im using a proven peice
Smurf6x6
Car: 93 CA18 Coupe
I did mine a few weeks ago. Easy job to do. I replace them with oem cause I bought a full engine gasket kit for a DE. Just make sure you have a valve spring compressor that ft the head. I just barrowed the one from work cause we have a CA specific one at nissan.
zil40
Car: 89 240sx
i need to replace valve seals and posibly valves can i use the ones for a 88 pulsar or do i order them for a cadet the head is at the shop now so if you guys could help me figure it out so i can tell them what to do thanx
OmarM
Car: 1989 Nissan 240sx HB
http://www.importperformanceparts.net
they sell a complete engine kit from AJUSA for like 100 bucks. Comes with valve stem seals.
