boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Fri Jun 18, 2004 9:55 am
Quote »Looking good Dee. I should be getting a package any day now from these wonderful mad scientists. Sent them a brand new (from OEM Surplus) head, new cam, and various misc. used parts to make a high performance head for a CA18ET. It's getting P&P'd, competition valves, HD dual valve springs, aluminum retainers, custom rocker arms, cam regrind to 270/.435.[/quote] I gotta watch you Alan;) ! That grind sounds a bit extreme and if your compression is going to be what you said you wanted, that's going to be an RSX/S2000 hunting N/A B11 sentra that will nearly put the smack down on it's prey. I mean let's face it, if I man handled B16 powered 99 and 2000 Sis with the B12 and a junkyard CA18DE, imagine the treat the others are in for. When do you plan on finishing everything. Oh and BTW, those are the valve springs you were referring to.
Dee
