float_6969 wrote:Just the opposite. You ALWAYS want your signal line for the wastegate to be as short as possible. If anything it might run slightly less boost than if you refrenced it to the manifold, as the pressure before the intercooler is generally slightly higher than after.
Other way around if you hook up the wastegate to the manifold. It delays the boost signal so if its for 7psi it'll go more. I have mine hooked up to my manifold until I get a MBC and my wastegate is set for 7psi but I get 10psi no creeps, spikes, consistant. So if the turbo produces 7psi and the intercooler creates a psi drop than the wastegate isnt getting 7 psi yet which means the turbo is going to produce more boost thus causing more boost.
