Keep what you got! We don't wanna go down the DE series camshafts debate again. The stock CA18DET cams will support your 400fwhp, but your current fueling arrangements will not.PulsarDet wrote:I just was wondering wish stock cam would be the best for a ca18det ? Since I start to have low budget I can't afford to have some tomei or hks camset.
So here the choice, CA16De, CA18DE, or keep the CA18DET one !If some body could confirm thisSeem the ca16 would be the bestthen come the ca18de since has some 8.8mm liftand the ca18de has 7.5mm lift ?
Here is the mod list.T3-T4 Ar.63 Spearco intercooler550cc injector and AFRZ32 maf 3" ehausxtstand alone with moded S14 ecu.
Planing doing 400hp at flywheel.Does it possible on the turbo with flowchar at 400hp still in the 70% effiencie.
Thank's alot !
They are referring to what type of lifter that you're using (ie lash or solid). The 8.5mm camshaft is excellent, but what is the duration. If you tell me 256 degree, I'll tell you to keep shopping.PulsarDet wrote:Well I finally got some reseller in canada, and the has a very good price, about 700$ CND+tx for a set of cam's and Pulley, the only thing I am sure is about lift and duration since the offre 8.5mm to 8.8mm in lash type or 9.25mm to 10.25 to solid type ? What is the diff and wish might be the best to stay with the stock spring and retainer since I would like not to spend 1.5K only on the head.
Thank a lot http://www.tomei-p.co.jp/_2003....html
The stock springs will work, if they are not worn already.PulsarDet wrote:I know what is duration but I assume the best combo would be maybe 8.5mm or 8.8 with about 270 duration but the reel question was, with the hydrolic lifter with is the lash type I guest does 8.8mm of lifth would work with stock spring and retainer or the valve will float about 8k rpm ?
sorry you're wrong about that. I've got a list of the specs for all the cams and the CA18DE is not the same as the DET. it's very similar to the 16de but slightly less agressive (1deg less advance)biosehnsucht wrote:all CA18/CA16 intake cams are the same, and ditto exhaust, with a single exception: the hard to find version of the Sunny in europe w/ CA16DE WITHOUT pollution controls has a different intake cam part#, and REPORTEDLY has a more aggressive cam profile. However, actually getting one if you can't hop down to the local euro (if you're in europe) yard and pull one from one of these, is essentially impossible. and only worth it if you could get it for free, and install it yourself, its not going to make any massive gains.
No cheap options unfortunately to get any real power.
