i have problem about my stage 3 CA18. here is explanation,
specs :
Z32 Maf
gt2860RS
PFC L-jetro
evo 9 injectors
walbro fuel pump
all forged internals
fmic
etc.
after i installed GT2860RS, i run it at 0.75 bar for 1 month . first days after i installed GT28 in 3rd Gear with stock injectors i see %96 duty. because of that i didn't push car at all.. but after 2-3 weeks, when i push car at 3rd gear when boost comes like 4000rpm likely some ignition cut or something starts to happen . 1st and 2nd gear this cut not appears. but in 3rd 4th 5th gear when boost comes car stops revving.
after 1-2 weeks , this cut starts to happen in 2nd gear. and afterwards it starts to cut even in 1st gear.
i think it was an boost leak in intercooler or something. i checked all lines and intercooler but any leaks at all .
so first i changed fuel pump - nothing changed-
fuel filter - nothing changed -
injectors - nothing changed -
coil packs - nothing changed -
sparks - nothing changed - ( NGK 8EIX 0.70 gap / 0.55 gap tried )
check coil pack harness and small grounding cables check - no problem at all -
still in every gear when i pass 0.7 cut happens .
then i tried to hold throttle like %70 and see boost like 0.6 or so.
in %70-75 throttle with 0.6 likely boost , car goes like hell. but when i pass 0.7 same cut happens.
then much worse thing happens .
when i get into this cut , car goes to 3 cylinder
the day after this 3 cylinder thing , when i was cruising and not boosting , car goes to 3 cylinder itself, then 2 cylinder and its stopped . i tried to start the car again , it starts if i only hold gas pedal %50 throttle. And so much unburned gas smoke is coming from exhaust.
in highway i pull over and change the spark plugs. when i uninstalled sparks , unburned gas smoke is coming from spark hole of 2nd cylinder. so i understand i have no spark on 2nd spark or coilpack.
after i changed sparks , car starts 3 cylinder and i drove the car to safe place to fix what is the problem ( safe place is a highway car park
i tried everything but car not goes to 4 cylinder normal work . so i leaved my car at car park and leave ( i was in a hurry ).
next day i go to carpark , and start the car again . still 2 or 3 cylinder. so cold it - start is doesn't work anymore..
i called a tow truck and towed my car to my home.
when i get home with car. i tried to start it again . but this time , car doesn't starts at all !
starter turns , but nothing happens , only some pops and bangs from exhaust when i force it to start.
it was a long story i'm sorry but i have to tell all details.
so... what do you think about it?
what sould i do ?
thank you
