themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.html
Mon Jun 11, 2007 6:12 pm
For the S14 you will need to loosen the compressor housing and rotate it slightly and file one hole on the CA turbo elbow a bit to clear on of the 14's studs. The colant lines are the same orientation. You should get a stellbraided oil delivery line for the new turbine as the hardline isn't a good match. You will have to bend the oil dump pipe to reorient it for the new turbo. The S14 has a two-bolt flage on the entrance to the compressor whereas the CA is round and receives the inlet hose directly. You will need to get some sort of inlet pipe to bolt onto the turbine so the hose will slide on. It's really just a lot of running around for little bits, I would consider it very bolt on.
