Two-Fortee »
https://forums.nicoclub.com/two-fortee-u80523.html
Sat Mar 22, 2008 10:15 pm
When you put on a T28, make sure you dont run past stock boost without some sort of tune. The t28 will run fine on stock boost, but don't go crazy with it (even though you may want to ) because you will lean out big time.
Best turbo for the CA to hit around 300hp is an s15 28 or GTI R t28. S14 t28 gets the job done too.
Anything higher than a T28 like a GT30 or something is going to cause huge lag and is probly not necessary for your goals.
