CA18DET turbo lines?
Maxstyle
Car: 89 240sx Hatch CA18DET, 2008 Altima Coupe
Does anyone know if i can use aftermarket briaded oil and water lines to a T25.
NismoBgt
Car: 1974 MBG GT with a CA18DET
You sure can! there is a bolt on adapter for the return that has NPT thread in it and you can go from the NPT to AN. The feed line is a little more difficult but any good pro shop should have or be able to order the metric to AN fitting you need. The block gets a little more difficult but if you do some hunting you can get the metric to an fittings you need. I purchased a majority of mine from Summit. Be prepaired to spend about $185 for the lines fittings and adapters. You can get the adapter off ebay for the return line on the base of the turbo cartridge. I had to weld on a fitting to the oil pan for the retun line.
kota2240
Car: 92 Nissan Coupe W/ CA18ddet
I used the TAKA lines and they fit perfectly
Maxstyle
TAKA did the trick. I ordered them last night. I'll post pics of the motor soon. She's just about finished.
