Hi Im new in this, I live in Costa Rica and I own a 240sx with a CA18det swap. At this moment Im playing with nistune and the car is running fine but I would like If some one can take a look in the BIN file to see if there is a problem or a incorrect setting.
The fuel map Im still working on the load areas.
What the engine have:
CP Pisons 84mm high compression 9.0.1
CA16de cam
460cc from mazda RX7
Garret T3/T4
Z32 MAF
FPR at 43psi in idle
FMI
The car in idle is between 15.0 / 13.8
On the street normal driving (no load) AF is 15/14
BIN file can be download in the link below
http://www.fileswap.com/dl/19EphKp1lC/
Any help or advise would be really appreciated. tnx
