krabstarr »
https://forums.nicoclub.com/krabstarr-u58420.html
Fri Aug 24, 2007 10:42 am
hey guys
i have some very frustrating problems with my ca18det ever since i have rebuilt the engine.
basically this was what was done to my engine:
- bigger pistons (83.5 mm) wiseco-wiseco multi layer steel head gasket-crank and rods balanced with SPEC clutch.-used grinding paste to clean up valve seats-changed valve seals-tomei high lift speings 10.25mm lift (around)-stock cams and stock camshafts-sr20det t25 turbo-new gaskets everywhere
and that pretty much it., i also took off the little flaps inside the intake that help the car idle better (apparently) along with the valve looking like thing that actuates the flaps (left the rod inside)
so basically, before i rebuilt my engine, it was running practicly perfect besides for some little idle problems and a misfire once in a while(didnt gap plugs and i used iridium :P)
so ever since i rebuilt the car, i have a hell of a hard time starting the car. it takes around 10-20 cranks before it starts up fine and in between those cranks, it starts up and then dies a couple of secs later. i have this problem when the engine is cold only
also, when the engine is cold, when i press the gas pedal too much, the engine just shuts off almost. what i mean is that ni press the gas and it stops firing or anything, the idle just goes down slowly as if i wasnt pressing the gas pedal at all. and sometimes it will sputter and backfire but wont go up in rpm.
then as the engine gets hotter and reach the optimal temperature, when i floor the gas suddenly (under no load) it backfires a few times at 3000 rpm and then goes up to whatever rpm it cuts off at. if i press the gas lightly it doesnt have any problems at all. its really when i suddenly open the throttle in one shot completely
when i take my car for a drive its a different story, when i press the gas gently while driving, it doesnt seem to have any problems besides for a lack of power for a few seconds while the turbo is spooling (in low rpm's) then once i reach around 3500rpm it start to sort of misfire or something. but then if i release the gas and restart pressing it gently, it revs up slightly higher and then starts misfiring /backfiring / sputtering again.
when i floor the car, it start pulling up to around 3500 rpm, but then it just starts misfiring/backfiring/sputtering liek crazy and the car stays at like 4000rpm!
i tried everything from timing to cehcking resistance and connections to all the electric components and even checking all the vaccum leaks on the intake!
THERE IS NOTHING WRONG WITH THE CAR i think
DID I FORGET TO CHECK ANYTHING OR SOMETHING??
is it possible that wiseco sent be pistons with a higher compression???
please help me guys! its already been close to 2 monthst that i have been trying to figure out the problem!
