i didnt have time to search,i was at work when i posted the thread. so the sr wiring a ca are the same?nab911 wrote:http://www.heavythrottle.com use the sr diagram... same thing... but search next time.
thanks for letting me know. i just sold my sr powered fastback and want something different.either a rb20det with t3t4 or ca18det.iliketocrash wrote:yes but i don't think the heavythrottle guide tells you what to do with the brown wire. it just says to connect it to a 12v switched source. in the case of the ca18det there is actually another brown wire to connect the original to the original one that is mentioned in the guide. this may sound a little confusing but you'll see what i mean when you read through the guide.
