ca18det t3/t4 topmount manifold
cuzan0
welp i was to lazy to pull out the old motor and put the purple one in,so i just took off the manifold and test fitted the sschrome t3/t4 manifold with my 38mm tial wastgate.,and i know i am missing a cam gear bolt i had to steal it for the other motor cause it was missing one,anyways the turbo fits nice with 2 1/2 to 3" inch clearance from the strut tower and same with the wastgate it clears about 3" inches too..
NeedCAforS13
Car: CA swapped S13 coupe
MORE PICTURES! lol, but that looks very nice:) I'd be interested to see how it holds up.
Sean
nab911
Car: 93 Nissan 240SX SE
Yeah... sure is pretty :). Mine looks that pretty... but with oil coming out of the turbo :(
quest
placement looks good... can't see any part of that pretty manifold.where is your ignitor positioned ?Waht turbo specs/ where u got it ? looks more like t04b compressorthanks
quest
nab911,u got your first t28? turbo that failed from blaast performance.How is the new t3/t04e holding up... looks good on paper.Did they exchange/upgrade to this one ?Anybody else have problems with blast or turbo calculator turbos ?
nab911
Lol well... i went straight from the tiny t25 to the t3/t04e from blaast, i blew it, got it replaced, and just blew the new one. I love blaast, they have the best customer service i have EVER seen. But its my faut i blew the turbo so im not going to send it back again. But i need to find what oil feed and drain lines i should be running because im pumping to much oil in that it cant move out.
quest
t3, stageII, t04E, 46trim warner/ihi is it ?Problem lies with routing your oil drain then ? I'm assuming you feed from stock location ?Good to hear customer service is top notch.Do you know of folks running blaast turbos sucessfully ? I'm looking for a t3/t04b and lloks like everybody took 'em down from their websites, except..... Too bad u blew another new turbo. Hope you sort it out.
boost_boy
Quote »I'm looking for a t3/t04b and lloks like everybody took 'em down from their websites, except..... [/quote] If you ever really need one, I can get you a decent deal. I think the T3/T04B stage I unit I used was the ultimate turbo for the CA18DET because it was flexible and very responsive and also did not lack too much.
Dee
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
can i have your cam gears?
- tim
boost_boy
Quote »can i have your cam gears?[/quote] Mine.......?
Dee
nab911
Lol dee hasnt had much luck with those ;). Yeah well im going to maybe switch to a non hardline drain today and see whatsup but i have to get my turbo rebuilt this weekend when i get my exhaust built. All i really need is some way to restrict the oil feed...
quest
thanks for the offer Dee. I'll most likely hit u up.I'll at least need for different projects;A 0.48/t3/stage1/Strim/t04b excellent on a street 1.8LLooking at a 0.63/t3/stageIII/Vtrim/t04b alsoI have the turbine housings. Prefer to rebuild my watercooled centers.I'll need a sr t25 machined for a "hot t28" cartridge too
You been in this game a while, so u may have a source for putting together 'reliable' turbos that last a bit for daily street use ?miami/ m.i.c. ?You get 360° thrust bearings in your turbos Dee, or opt not for the boost levels you run ?
boost_boy
Quote »You get 360° thrust bearings in your turbos Dee, or opt not for the boost levels you run ?[/quote] I paid a lil extra, but well and worth it. And as for the hook-up, that area I mosy definitely have on lock. Just let me know when you're ready and I can get it all set up.
Dee
