chefneiman »
https://forums.nicoclub.com/chefneiman-u120523.html
Mon Dec 15, 2008 6:34 pm
Hi guys and gals,
I recently swapped a Ca18det into my Convertible... Motor starts and runs perfectly, but ever since the swap, I cannot seem to get the Top to go UP or Down.
Here is what I have checked...
1. There is fluid in the Hydraulic Pump...2. Top Stack Fuses behind driver's side kick panel are good..3. I can get the top to work by placing my battery in the trunk and manually touching the Top wires to the battery posts...
Now, don't know if this affects anything, but the Speedometer does not work either, and the speedo cable is installed and plugged in.
Perhaps someone on here has some insight on this...
thanks much!
-Mikhail
