ok, my Ca18det swap into a 90 hatch, no power options is nearly complete, except i have one connector comming out of the main harness/ also hooked into the ECU that doesnt fit the 90s connector, the connector is on a bracket, the braket is located on the kickpanel pillar near where the door opens if you take out the glove box its there on the right, its a white connector with about 7 wires in it. the Ca18det harness has the same connector but, it was wired with the plug from a 91 so it wont fit my car, the coloring of the wires is also differnt, i have the pinouts for the Ca18det ECU so i can figure out what they are for on that end of things, but i dont know the pinouts for the Chasis's connector, can anyone help me by listing what color wire does what, or a place i can find the online FSM for the 90s 240sx
thanks if you need more detailed explanations IM me at Sidefxs1 or post here!!!
Jon
