Ca18det swap
drifting circles
Car: 240sx
Ok i just bought a ca18det and it is wired for the dohc what has to change since i have the sohc???
float_6969
Nothing. You'll just need to run a direct wire from the knock sensor to the ECU. It needs to be sheilded as well BTW. Pin 23.
ca18drifta
Car: 240sx
Thats it huh thought there might be a little more work.
ILOVESILVIA(S13)
Car: 93 Ca18det Hatch, 03 Subaru WRX Wagon (daily), Subaru Legacy Limited GT (daily)
Where is the Knock sensor located by the way?? And what does it look like? I still need to get that done before i finish my swap too.
float_6969
On the block, under the intake manifold, dead center on the motor between the 2nd and 3rd cylnders, near the top of the block, up by the head. It's a single wire sensor IIRC, but it's sheilded.
tattman77
Car: 92 240sx coupe w/ca18det swap top mount 20G and s13 silvia front end
And don't freak out when your stock tachometer does not work.You will need a dohc or aftermarket tach. if you like to see your rpm's. In case you did not know this yet.
Reno
Car: 89 S13, boosted.. RAWR..
tattman77 wrote:And don't freak out when your stock tachometer does not work.You will need a dohc or aftermarket tach. if you like to see your rpm's. In case you did not know this yet.
so if we have both kph and mph would the speed to be read work on our tach?? 92 240sx btw..
float_6969
You need to use your KA speed sensor to have the speedo work properly. I'd be suprised if there isn't a KA speed sensor in there already if the guy had it in the car and working.
Reno
hmmm not to tthreadjack but where a good place to get the ca motorset?? jhot? jarco osaka?? uh... lol??
burntricer
Car: 90 S13 SR20DET Redtop
so the KA transmission will bolt up to the CA? or no?
Chris859
No, it won't... Well, not directly. It would if you swapped bellhousings.
