asher4857 »
https://forums.nicoclub.com/asher4857-u15882.html
Sat Feb 24, 2007 12:58 pm
Internet Etiquette requires that if you make a most, do not make a second one unless it cannot be found (your profile should give you a link to posts you've created) as well as if your post is already on the front page, give it some time, someone will respond, if your post falls behind, give it a bump. JUST ONE BUMP.
With that said, just give it a chance, the CA forums are slow. Someone will answer eventually.
