ca18det swap in a s13
240SXinTX
Another ca question.... i have searched and i have been reading that the ca wiring is the same as the sr. is this 100% true? can i follow the exact steps for the sr swap and have it work on my ca?? For instance, on the sr harness there are two plugs that run up behind the battery that you have to cut and splice with ka plugs. is this the same wiht the ca??thanks.
float_6969
Yes. It's just like wiring up an SR. The only problem is that you have to run a wire for the knock sensor directly to the computer. It was designed to run through the lower harness in the stock setup, but since the knock sensor runs through the engine harness on the SR and KA, there isn't any wire in the lower harness of the KA.
240SXinTX
Where on the ecu does the knock sensor wire go? just so im sure the knock sensor that comes out of the ca block will have some wires that need to go directly to the ca ecu.... completely avoiding the harness.. right?
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Pin 28 if I remember correctly. You can actually wire it to the upper harness behind the battery if you want, but itll be fine either way.
Jiggyfry
240SXinTX wrote:Another ca question.... i have searched and i have been reading that the ca wiring is the same as the sr. is this 100% true? can i follow the exact steps for the sr swap and have it work on my ca?? For instance, on the sr harness there are two plugs that run up behind the battery that you have to cut and splice with ka plugs. is this the same wiht the ca??thanks.
When i recently did the CA swap I followed the SR wiring guide to the letter. Everything is the same, even the wire colors. The wiring is quite easy if you take your time and double check everything. And yes, the 2 plugs behind the battery also have to be wired in just like the SR swap. Do your research using the stickies and it'll be a breeze for you. Good luck!!!!
240SXinTX
Thanks guys!! lol, it seems like the ca forum guys are nicer then the sr guys... so pin 28?? anyone got a ecu diagram? also, if i chose to run it to a wire behind the battery, which wire is it? I assume its one of the two plugs behind the bat, but wat color? thanks guys!
Jiggyfry
All your questions can be answered by reading the stickies. Tons of info there to guide you along as you do the swap. There is also a FSM that you can download and it comes with an ECU Pinout diagram.
Lets see some pics of your ride!!!
capowered240
Car: 90 240sx
r34 gtr wrote:Pin 28 if I remember correctly.
Wrong, Pin 23, White wire
r34 gtr
Gah! every time!
240SXinTX
jiggy180 wrote:All your questions can be answered by reading the stickies. Tons of info there to guide you along as you do the swap. There is also a FSM that you can download and it comes with an ECU Pinout diagram.
lol iunno, my car is such a piece right now.. 300 bux...
Masterdebater
Car: 1989 nissan 240sx coupe
wiring the ca was easier than putting the dam motor in haha
240SXinTX
back on the topic of the knock sensor, it is down by the crank right? or is it on the head???
Jiggyfry
Its under the intake manifold, I believe around runners 2-3.
Masterdebater
yea its the green looking plug jutting out of the block under the intake manifold
240SXinTX
sweet, thanks.
turbodcivic
uh oh, heres my wiring pics,
INT wiring only
plugs side by side
everything all done and extra wires depinned
i did the same thing with the engine harness. i made little jumpers so i didnt have to cut my CA harness.
Jiggyfry
Nicceeee!
Im so happy, you went from a question thread to a build thread. You have almost graduated grasshoppper, carry on young sir!
turbodcivic
its not my build thread but what the hell, for referance!
make sure you take this off your ca transmission
you CAN run your factory KA ac compressor and lines, i didnt even disconect anything! pushed it to the side and hooked it directly up to my CA bracket ( you gotta run another power steering belt which it 2 ribbed)
and there we go.
im not sure if the above post was sarcasm of what, but i hope it helps
mbmbmb23
turbodcivic wrote: ( you gotta run another power steering belt which it 2 ribbed)
Do you have a part number for the 2 ribbed belt you used?
thanks,
-Matt
turbodcivic
i just used my power steering belt since my car is a 90 and i didnt have the cash to buy a 91-94 high pressure hose.
just go to autozone or something and buy another power steering belt.
Jiggyfry
No sarcasm from me at all man. A lot of people end up giving up on their projects. Its nice to see people come in and ask questions, get the answers they need and carry on working.
By the way, your engine looks REALLY clean!
turbodcivic
right on man, i got alot of compliments saying, " man your swap looks so clean , like you just shipped a whole car over"
so i take pride in my work
heres some more i took last night
these pics taken with a nikon D80 and a 12 second shutter speed.
i dont mean to threadjack by any means, but i know this guy got his question answered and then some lol
Jiggyfry
Ok, my bad I thought turbodcivic was the OP. Still a nice car.
You should probably make your own thread for your build so I may drool there and not upset the OP in case he has more questions or he wants to post his own pics.
