ca18det swap guide?
alowishus
Car: 1990 240sx
I am having trouble locating one. Is it so easy that literally all you have to do is drop in the motor/transmission and hook everything up? No modifications needed or anything (like the sr20det)?
damesta
Just like swapping in an sr, no major mods needed.
M374llic4
Car: 04 Titan, 89 KAT
you have to relocate your flux capacitor reservoir to underneither your vtec emitter control valve.
teddy
Car: Saab Turbo and MR2
M374llic4 wrote:you have to relocate your flux capacitor reservoir to underneither your vtec emitter control valve.
Yeah...that part is a bit tricky. I had to go back to 1988 just to find one.
It's really simple though. Pull the KA, follow the guide for the sr's and just drop the motor in. Modify the harness, and hook all the hoses up and you should be a ok.
alowishus
Car: 1990 240sx
why do that when I can buy a new one?http://kalecoauto.com/index.ph...id=28
alowishus
Car: 1990 240sx
I forgot to ask, do I have to use DOHC ka power steering lines or will the SOHC ones do?
capwred
DOHC ka power steering lines will do.
Rookieca18det
Car: 93 hatchback (ca18det)
i just left kade pump in the car attached then the ca power steering pulleyl was put on the ka pump.
-richard
alowishus
Car: 1990 240sx
I have a SOHC ka24e though. Do I HAVE to get the DOHC lines?
Sil40sK
Car: '93 Nissan 240SX
'88 Porsche 911
'02 Ford Focus SVT
I've heard of some people cutting and re-flarring their sohc lines but I don't know the legistics of it. Personally I would say, don't half-*** something as important as steering and just buy some DOHC lines. They arn't all that expensive when you get them used.
alowishus
Car: 1990 240sx
ok thanks
