Ca18det swap from 91USDM to a 90USDM wiring color ?'s
slw240sx
Car: 1990 Ca18det 240sx Hatch
Ca18det swap USDM wiring color question
ok, my Ca18det swap into a 90 hatch, no power options is nearly complete, except i have one connector comming out of the main harness/ also hooked into the ECU that doesnt fit the 90s connector, the connector is on a bracket, the braket is located on the kickpanel pillar near where the door opens if you take out the glove box its there on the right, its a white connector with about 7 wires in it. the Ca18det harness has the same connector but, it was wired with the plug from a 91 so it wont fit my car, the coloring of the wires is also differnt, i have the pinouts for the Ca18det ECU so i can figure out what they are for on that end of things, but i dont know the pinouts for the Chasis's connector, can anyone help me by listing what color wire does what, or a place i can find the online FSM for the 90s 240sx
thanks if you need more detailed explanations IM me at Sidefxs1or post here!!!
Jon
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
i used the fsm for the ca18det and the fsm for the 1989-90 240sx, i mainly just matched wire colors, i also used the white connector from the 240sx harness, i just pushed out the pins and put the new ones(from the ca18 harness) in. my car runs, for the most part (nothing wiring realted), so i can safely say this works.
slw240sx
i dont have the USDM 90 FSm and i dont plan on buying it now either since i have a CA18det in the car.. i was just goin to repinn the brown connector into the 90 since i have both the male an female parts, i only have the female connector from the 90
