CA18det swap, 89 240 help
Iggybcool
Hey guys new to the forums and new to Nissans. I'm doing a ca swap into my 89 240 with my cousin. We're both mechanically inclided and have the tools. Could someone please post up a write up or some information so we don't steer off course?
Thanks,Justin.
p.s. I did search and it only returned up FS: ads.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
http://www.srswap.com Look in the FAQ It's the same as the CA down to the wire colors.
tyrannix
Car: go big or go home
with the exception that you can use the radiator from your 240sx with the CA, and use the radiator hoses as well
(SRs have to get a different radiator)
CJ
Iggybcool
Thanks man really appreciated!!!! So the whole ca swap is the same as the sr swap? Is there a specific sr like the red-top black top or the s14 t28
driftin8ez
Car: 92 Coupe, Turbo Miata
c-rad wrote:http://www.srswap.com Look in the FAQ It's the same as the CA down to the wire colors.
just follow the guide found here and you should do fine. Also here is a link to a great wiring guide:http://www.frsport.com/sr20det....htmlNow stop reading on the forums and go finish your swap!
jdotlim
thats wiring is easy to follow...im doing my swap soon so im reading up on it...thanks
UMS_CA18DET
you gotta be kidding me, to do the wiring is that insanly easy?
Geeze why are so many people having trouble with it, if its that straight forward.
Trigger
some people cant read
Axlerod
Car: 1989 180SX
Don't forget the knock sensor is on the lower harness for the CA
