things on the list already are as follows:
godspeed rods with acl bearings and arp bolts
cp or weisco or wassner? pistons 8:5:1 or 9:0:1 ratio @ 83.5 bore
cometic head gasket
arp main studs
block cleand bored and honed
head shaved if needed
crank bearing journals ground if needed
new oil/water pump
560-1000 cc denso or sard injectors?
rising rate fuel regulator
bosh 040 feul pump
i would like to know what turbo to use that will give nice linear curve from as low in the rev range as poss and keep pushing through to 8500 rpm also what else should be done to acheive as much torque as poss at 350 kw @ 6400rpm.....thanks guys and keep the ca alive
grasshopperps13
Car: ps13 (91) with a ca18de.....building ca18det from ground up!
* Private message
Top
