sorry for the noobness, but whats fsm?zenki-S13 wrote:not sure on the sputteringbut you can find how to read the codes in the fsm
I doubt it.Nathan A. wrote:I checked out the intake and hoses, and i'm pretty sure its not that. I had a wiring/electronics genius come by and he said that I needed a new ECU because my injector coils weren't being told to fire. Does any of that make sense?
yeah, it runs normally until boost then starts sputtering like it isn't getting enough of something. I guess I'll just talk to the electronics dude about it again.float_6969 wrote:He said the injectors aren't firing? I thought it ran, just not in boost?
fuel pressure and pump are both fine. He said that the spark plugs were firing but the injectors weren't and that it has something to do with the ECU.meminto wrote:Hows the fuel pressure and the pump?
From an electronics perspective, check the power transistor (ignitor) I didn't understand the ecu/no fire explanation (injector coil?), it didn't seem logical..
