MeanGreenS13 wrote:check engine light should be within that brown/white plug under your dash, should have been connected when you wired the motor up, as for the Speedo, i dont know maybe your speedo sensor is taking a **** on you, OR maybe you have a bad cluster? not sure man, maybe some of the others can shoot you some ideas
How does the brown and white plug under the dash get connected to the ECU? I wired it like this inside the car.
I also swapped it for another cluster.. prob the sensor. then. Would it be the same sensor as the KA transmission? same things right?
Thanks
