CA18DET S14 swap Questions...
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Shally, sell me your stock PCV hose that runs from the Intake manifold to the valve cover lol.
Definitely do your thinking and research on this one. Do a compression test on the CA for sure. It would be cool in the S14.5 for sure do what you really want!
shally2186
Car: S14.5
OM3GA wrote:Shally, sell me your stock PCV hose that runs from the Intake manifold to the valve cover lol.
Thanks for the Feedback! Why do u need that PCV hose? isnt it like a normal hose u can just replace? appreciate positive thoughts, cause every SR fanboy around here thinks i dnt know what im doing ... COMPRESSION TEST FTMFW!!!
shally2186
Car: S14.5
So a good friend of mine who runs a CA18DET over in Sweden told me; "put a good oil cooler ,and raise the max oil pressuare by 0,5 bar by adding a 0,5 mm distans to the overflov spring in the oilpump."
Now is this VERY Necessary? im not too sure what he means about the oil pump
float_6969
The guys over in the UK and Europe SWEAR the CA has problems with the rod bearings. I've never seen problems over here in the US, but those guys have been pushing the CA to it's limits for a lot longer than we have.
The oil pump mod is SUPER simple if the motor is out of the car. I'm going to do it to mine when I drop to pan to replace the rod bolts. I'm shimming the oil pump and replacing the rod bolts because of the input that I'm getting from them. I'd rather not find out if they're right or not.
As for the cooler, it's the same concept. It keeps the oil from thinning out.
shally2186
Car: S14.5
float_6969 wrote:The guys over in the UK and Europe SWEAR the CA has problems with the rod bearings. I've never seen problems over here in the US, but those guys have been pushing the CA to it's limits for a lot longer than we have.
Sounds good! THANKS ALOT!!! i guess i can go ahead and do those then,i just really hate tampering with oil stuff cause ive saw too many engines blowing up because they hooked lines up wrong...
Speedracer5767
Car: 95 240 SE-SR20DET-3"exhaust-HKS SSQV BOV-VLSD-FMIC-Greddy GRacer lip-4300K HID's-AEM UEGO WIDEBAND-AUTOMETER CF Boost gauge-Go Pro Hero Cam
I am currently doing the same swap into my 95. What did you do about the MAF? Mine is wired for the CA, but I don't have that MAF. I only have one for a Q45 or Stock KA24DE. I have searched with no luck, just "try this, it MIGHT work!" I really don't want to F it up. Also , im running a T3/T04E. Not sure what injectors tho. This is my first 240, as I am a Honda fan and have done swaps, turbos, etc. Im a NEWB. Any suggestions? Thanks.
shally2186
Car: S14.5
Are you running a Stock CA?? A T3/T04E then u may wanna think about building the internals up.. I am running the stock MAF with Stock injectors and just a DBB T28 S15 Turbo.. As for your injector size i would recommend anywhere in the 500's, but that mainly depends on how much power you are looking to push out of it.
OK guys, Got the CA Last week..a Few updates..
Took the kit off and its getting painted while the CA is getting drop'd in
Custom did my Dash to Fit my HKS Gauges and Turbo Timer..
shally2186
Car: S14.5
Updates:
float_6969
Your getting there! If you need inspiration pics, LMK and I can send you some pics of my engine bay as it sits. The car runs and drives but I still have A LOT I still need to do.
shally2186
Car: S14.5
float_6969 wrote:Your getting there! If you need inspiration pics, LMK and I can send you some pics of my engine bay as it sits. The car runs and drives but I still have A LOT I still need to do.
Please send me some pics! I always try to fins some but come up empty handed.. Vids of it runing would be amazing also!
shally2186
Car: S14.5
So the S14.5 CA18DET should be done 2morrowISH.. Finally coming home so i can play w her alil..only Prob So far is some White smoke coming out the exhaust.. Hope it can be a simple fix but im thinkin the worst...
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
please send me a ca to s14 wiring diagram lol
shally2186
Car: S14.5
Swap is in and done.. Car Runs good!
float_6969
congrats!
s13drifter88
dude that is sex on ice bro. sh*t's clean man. congrats. what'd it take to wire a ca in an s14???
shally2186
Car: S14.5
just have to wire up the speedo some how and getting ready for fresh paint
float_6969
Nice!
DS240sx
Car: S14 Zenki 240sx
Hey sorry to bring up this old thread but could you PLEASE send me the wiring diagram from ca18 to s14??? This would help me out a lot and I've been searching a lot and couldn't find any info.
float_6969
This guys has been MIA since this post. We don't know that he ever even finished it.
As for a wiring diagram, AFAIK, there isn't a diagram to wire a CA into an S14. I have a standalone, which is easier to wire up than the stock CA harness/ECU, and it still took me hours to figure it all out and wire it up.
The only way you're going to be able to do this is if you get REALLY familiar with automotive electrical and how it works, or pay someone to build the harness for you (wiring specialties)
DS240sx
I had someone modify the harness, so I just have to plug all the plugs. I was wondering if it is like plugging in a SR into a S14? This is my first swap so I'm new to everything sorry...
Thanks for the info
mdb4879
Car: 1987 Nissan Pulsar SE (CA18DET)
1990 Nissan 240SX (KA24E)
1995 Acura Integra GSR
I have no experience in this whatsoever, but I would imagine if a CA into S13 is like an S13 SR into S13 then a CA into S14 should be like an S13 SR into S14.
float_6969
It is VERY similar to an S13 SR into an S14, but not exactly.
