tyrannix »
https://forums.nicoclub.com/tyrannix-u27595.html
Wed Nov 01, 2006 4:47 pm
yeah, that sounds like your problem, standalone FTW (and you can sell the chip + ECU to recoupe some money)
theres stickies on Megasquirt and Emanage, and a conglomorate one on pluses and minuses of different ones
you can get into an SDS or megasquirt for under ~+-1000 out the door
the squirt can go as low as a few hundred if you assemble from kits and do everything yourself, but you can buy ones already built with options like efans and butterflies it interfaces with a computer and you can get a hand controller for itand its completly open source if youre a nerd like me and like to program, youll like it
SDS is all built out of the box, youll need to put magnets on your crank and build a bracket (in most cases youll do that with the squirt too, but dont have to) but SDS is supposed to be a whole lot easier to program, and modify the tables with the hand controller
both of those you will need to make your own harness
Plug in optionsApex PowerFC (i just sold one, i forget the dudes username, but hees using it this weekend, we will see the results)
Greddy Emanage, see sticky for description, i have never seen or touched or know anything
AEM, or alot of other plug and play ones. you can use an SR one if you repin your ECU plug
i really reccommend a standalone, as youll always be able to retune it (when you get a wideband) yourself whenever you get a new mod, then just go do 1 dyno run to see your numbers instead of having to tune on it
CJ
