CA18DET S13 Auto transmission Problem
jackchoo
Car: Nissan 200SX S13 Fastback CA18DET Auto
anyone there who can help?? This is a S13 Auto transmission by the way...
update : I notice that it happens quite predictably :-
- from a cold start (after 2-3 minutes warm up)- after 6-7 minutes of driving- at that point I'm normally in heavy traffic so coasting real slow towards the freeway entrance- enter freeway, accelerate- and it cannot get out of first gear!!!- stop the car dangerously by the side- and its all ok for the rest of the journey! till the next cold start go back to the top.
It pulls out a code 43 when this happens (TPS) for the TCM and ECM. But I've already swapped with a good tps and have even checked it on a scope first.
One question though : is the TPS harness 0V reference supposed to be directly grounded to the battery. My multimeter seems to show a direct short to body/battery ground.
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
I'd like to help you, but CA's aren't my specialty. Check the CA forum.
2the40
Car: Genesis
I had a similar problem with mine. Search the 240sx vert. forum.
I unplugged the revolution sensor and the problem vanished. I guess there is a back-up system. But check the vert. forums anyway.
