boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Sun Aug 26, 2007 1:12 pm
Some food for thought for everyone that cares to read, and Chris, by no means am I trying to down-play anything you say as I do have the utmost repsect for you, but a used stock nissan JDM CA18DET with minimal wear to it's bearings, at least 140psi of pressure per cylinder and some healthy oil presure from the oil pump can support over 400whp granted you have a decent engine management system, that's well-tuned, and also have the supporting components to boot.
Though the rod bolts can be blamed as problem area, it is not a CA18DET weak link. The problem is that these engines were abused before you got it. The bearings were already worn, but yet you try and rev the schnott out of the thing like it's a fresh rebuild or something? If your bottm end shows heavy wear, you may want to get the problem areas looked at by a competent machine shop. Excessively abused engines should have their rod bolts check for stretching, but I seriously doubt they would've stretched.
Though the headgasket has been said to be a weak link, it is not. If the engine has been over-heated before, the headgasket is already in trouble. You don't know what your engine has gone through before it made it to you, but then you go and crank-up the boost and advance the timing a bit whilst using a side mount intercooler? Sorry guys, but you can kiss your headgasket, pistons, bearings, head, bearings, and/or rings goodbye. Pushing the stock ECCS system past it's limits will usually kill engine components. Pushing the stock turbo past it's efficiency band usually creates a huge problem in the area of detonation which destroys pistons and melts heads as well. Advancing the timing onthis thing like it's some honda engine or SR20DET is just absolute retarded and anyone that has done it is just plain hard-headed. You want more power, spend some money.
Though the pistons have said to be good up to 300whp, that's a crock of $hit. These pistons are not as weak as you think. Hell, I've destroyed some fresh wiseco slugs back in 1999 in less than 1,000miles and this was due to poor engine management. And this was done on low boost. I've gotten more than 400whp daily out of the stock CA pistons and the 300whp and the stock CA pistons are a gimme if you know what you're doing. So this myth about the CA pistons is just what it is .........
For you rod bolt bandits: I have measured the length of numerous CA18DET rod bolts in my garage and the conclusion is see no evidence of rod bolts stretching. I have a gang of rods and went above and beyond to try and back-up this new theory about CA rod bolts being too small and stretching and I'm sorry to conclude that I cannot find the evidence to support this rod bolt stretching thing. I don't know who started this and I honestly don't care, but may I suggest some of you do your own leg-work to determine a part on your motor is out of spec as opposed to buying into rumors because you're going to find yourself spending money foolishly on stuff you really don't need.
In closing, the rods that are in my sentra's engine has been around for a long, long, long time and I have never even looked at the rod bolts as problem are, even when I was experiencing crank issues. An align-bore squared away my problem and I 2-step at 7000rpm and rev the oil out of this engine. Headbolts, if you're doing headwork, just buy you a new set as those do stretch and have crewed myself with this a long time ago. Or you guys can just do whatever! I'm just trying to help some of you who are possibly confused as to what's where or why. As usual, good luck!
Dee
