silviaS13lover wrote:so after i pulled the engine out and tore it down, i found that the #1 rodbearing had spun. not exactly sure why yet
Cause by the same problem in early RB26 motors. Too much oil goes to the head, bottom end starts starving out. Always happens to # 1 due to the pump sucking away all the oil. Happens after sustained high revs.
Solution : oil restrictors in head. Lgihter oil. More oil then when full (extra 500ml)
Or don't rev the crap out of your motor :P
Some RB26s guy tap in another drainbacck hole and plumb it to their sumps.
Good luck.
How do I know this? Happened to me and did a bunch of research :P Had friend that builds RBs for a living to concur
