Ca18det-r
undertaker
Car: C33
i was wondering if any of you have any information on or have seen this motor. i know it was installed in the RNU12 SSS-R Bluebird rally car (transverse 4WD), the 'R' means it has a bigger turbo and it was specified at 185PS. if the RB20DET-R is anything to go by it could have some seriously nice standard equipment capable of far greater power than specified. i have seen one of these cars but didn't get to have a look at the motor :(
paul_s13
I've never heard of a ca18det-r! :confused: if rare motors are you bag then go for an FJ20ET I'd ditch the CA for one of those bad boys! :D
themadscientist
pick up one tommorow.hi lift cams with adjustable sprockets2.1 overbore pistons and metal head gasketHKS turbo kit and 550 injectorsOS twin plate and crossmissionIt should drop into Damien quite nicely:D
undertaker
Car: C33
FJ's aren't exactly rare here, the S12 photos posted in the FJ20 thread is from NZ. It ran a 10.8 with some development to come so there is no question it has lots of potential. And an Aussie S14 with a FJ has run a high 7s 1/4!I'm just interested in the DET-R because i like CA's and it seems to be the best factory version. The car comes with a close ratio and half cage from the factory plus some other improvements.
themadscientist
it's also 4wd and likely not a prodution car for sale to the public.. Any DET is fine they are all monolithic power generators built.
undertaker
Car: C33
True enough but there are a couple of these at least over here. I guess i will have to try to get another look at the car i saw previously.
themadscientist
well it can't be that great, it's only 10ps over a plain jane CA18DET. The GTS-R R31 wasn't that great either. Sure it had a T04 and a nice manifold but the parts in it did not work together smoothly and the reveiws were poor on it. The CA is balls you can't go wrong either way:)
Spectre_240sx
Car: 1990 240sx SE
Then again, the CA itself makes 30 less HP than the SR. Why not just go with the SR instead? The potential of the engine might make it worth it. That's certainly why people go with the CA over the SR.
sr20meplease
Car: cars
Spectre_240sx wrote:Then again, the CA itself makes 30 less HP than the SR. Why not just go with the SR instead? The potential of the engine might make it worth it. That's certainly why people go with the CA over the SR.
bad place to say to take a sr over a ca.....
themadscientist
He didn't say that, read the last sentence again. The SR is a great motor compared to the other four bangers out there just not the CA.
sr20meplease
Car: cars
i know i was just messing around
Spectre_240sx
Car: 1990 240sx SE
Hooo-ray for the CA.
Note: should have mine in a few weeks :)
paul_s13
I'd sell my CA and fit a Ford BDT (RS 200) engine, now that would be sweet. :D
But it cost too much :(
undertaker
Car: C33
i hear you man. i saw a mk3 cortina GT with a cossie motor (2L DOHC turbo but not RS 200), really nice but the guy had spent a lot on it and a fj/ca/sr with that sort of investment would hose it.
paul_s13
undertaker wrote:i hear you man. i saw a mk3 cortina GT with a cossie motor (2L DOHC turbo but not RS 200), really nice but the guy had spent a lot on it and a fj/ca/sr with that sort of investment would hose it.
If your talking about the Cosworth YB engine then I doubt the Nissan engines will hose it, its a fantastically strong engine and here in the U.K. tuning bits are very very common, it costs a hell of alot more here to mod a CA/SR they prices are rediculous. :mad: :(
undertaker
Car: C33
nissans are cheaper and more common here. i have heard the cosworth motors are strong from the factory, any idea what sort of power they can produce on standard internals?
paul_s13
Well a common stage 1 upgrade is 330bhp and the crank is good for over 500bhp (BHP measured with the DIN measurement not the US SAE measurement) it produces a huge amount of torque compared to Japanese 4 cylinders and when its bored to 2.4 you tend to get more torque than bhp, its not a massivley high revving engine but its dirt cheap (comparitivley speaking) to modify and the support in the UK is huge.
I believe 350bhp is fine in standard internals but you may have to drop the CR.
