float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sat Aug 21, 2004 12:31 pm
OK, here's my look on it. I was kind of in the same boat you are. I had a KAE in my car and hadn't actually planned on swapping the motor until after I had the suspension sorted out. The problem was that my KAE had about 210K miles on it. It started buring oil pretty badly about 2 months after I got it, then an exhaust manifold bolt broke off in the head and started leaking exhaust into the engine bay and I kept melting spark plug wires. For me I had to have a new motor. The money that I would have had to invest to fix the one I had warrented my purchasing the motor that I wanted for the car eventually anyway, so I did so. My problem was that the motor that I got wasn't in a whole lot better shape than the one that I took out. I'm currently rebuilding my CA due to a bad set rings. Also all the rod bearings were worn and the was some scoring on the #3 cylnder and piston. Unfortunatly I was one of the unlucky ones and got a motor that had been beaten on. Most actually seem to be more lucky than that. Ultimatly, the choice is yours. If your motor isn't running well and needs replaced, then put the motor you want in it. If it's running fine, then it will probabally continue to run well for at least the next year or so. I would personally put more money into your suspension, wheels, tires, seats, & steering wheel. This is from experience. I've had a 240 with a stock motor and badarse suspension and a 240 with a stock suspension and badarse motor. I'd take the good handling 240 over a powerful 240 anyday, no questions asked.
