Sideways s12 wrote:Hey guys I need some help again I have this issue with the ca when driving and I try to accelerate from a stop it kinda bogs down and doesn't want to go then when it gets to a certain rpm it takes off but still rides rough and isn't running at it's full potential if I go WOT the boost gauge reads 15psi which is where it's set but it's def not 15psi the turbo is still good I've checked it. I almost think it's a tps problem but the way it's acting makes me think it's something else. ANYBODY have any ideas on what it could be also how can I check the tps to see if it's still good? Also the plug for the tps kinda fell apart so I had to wire it up using female plugs from autozone but I'm not sure what order the wires go in...Any help would appreciated thanks.
Check for codes on your ecu and if there's any, report them back here and I'll give you my thoughts on what's causing them. If there is no codes, focus on your TPS plug issue. Once corrected and that doesn't help, watch out for a faulty oxygen sensor as these can cause the CA to run poorly as well. The next major area is Crank Angle Sensor, but try the others first to see how it goes. I had that issue for a long time back in 2000 in my fiance's (at the time) 1990 nissan sentra with the first USDM nissan pulsar ecu re-programmed by JWT. The car would be at 15psi, but it felt like I was only running stock boost. I tried everything imagineable up to and including taking the JWT ecu out of my personal 1990 sentra and putting it in hers and at that time, I said screw it and bought my first SDS standalone in 2001. Once I intsalled that system and worked-out the tuning, the car was wicked on the street, admirable on the drag strip and I never looked back. Just some food for thought as I know everyone don't have $1700 to throw away on a computer system, but the investment was well and worth and paid for itself over time.
