mbmbmb23 »
https://forums.nicoclub.com/mbmbmb23-u19119.html
Wed Jan 23, 2008 3:40 pm
Pull each coil pack with the car running (one at a time).......and the one pack that gets pulled that doesnt make the car run worse is the one to look at. If pulling each coil makes it runs worse (each of the 4 times)......then its something else.
If you locate which cylinder isnt firing, swap the spark plug from a good cylinder to that bad one and try the test again........if its the same results...you have a bad coil pack and the plugs are fine.
-m
