Hi guys.
I have the following mods on my CA18DET.
resurfaced block
block was bored to 83.5mm and honed
8.5:1 83.5mm CP pistons
Pauter connecting rods
Resurfaced oem crank shaft
ACL race bearings (properly sized based on crankshaft)
Supertech dual valve springs
Supertech intake/exhaust valves
Tomei 260/8.8mm cams (same for intake and exhaust)
haltech platinum sport 1000
t3 .50 trim .48 a/r
I had recently finished my build of the engine with a resurfaced block/head and cometic head gasket with arp head studs. The rings are installed correctly, seated and engine is broken in. The engine showed 150psi +/- 0.5 psi across all 4 cylinders. It started and ran absolutely perfect. I broke the engine in as per the instructions here (
http://www.mototuneusa.com/break_in_secrets.htm) at the recommendation of float_6969 in a different post.
I have not boosted much. The first time i got into boost (roughly 1 bar... slightly less) the engine started acting funny so i immediately drove it home (a couple blocks) at which point it died. I did notice if I made left hand turns it would run on 2/3 cylinders. I assume it's something electrical since oil and fuel pressure are both good. Temperatures were 170-180 fahrenheit while driving and boosting.
I popped the hood and could see oil coming from the Cometic head gasket all around.Ran a compression test which was showing 140psi across all 4 cylinders after this. I swapped the Cometic head gasket for an OEM nissan head gasket I had lying around. Compression test still shows 140psi across all 4 cylinders. I started it up to see if it would run and I got the following result.
[youtube]
http://www.youtube.com/watch?v=ypfgiq0Y1UM[/youtube]
So I'm curious if anyone can provide feedback as to what could cause the compression #s to go from 150 to 140. There does not appear to be any blow-by. The head gasket is not leaking either. I think the reason it's running off only cylinders 2 and 3 is because of the coil packs. I saw that they are arcing at the base of the plug on more than one cylinder. I'm going to see if I can find another harness in my spare parts to re-test. Cylinders 1 and 4 are wet with fuel after cranking, 2 and 3 look normal.
I tried re-starting it now and it just cranks. It won't even start like in the video above. I re-checked the numbers and i'm still getting 140psi across all 4.... so it seems like it may not even be related to the compression numbers but I would like people's opinions on what could cause the numbers to change that much anyway.
I provided back story for all of this and the coil pack info to be thorough. It's not my daily driver but I do have a dyno session scheduled for Saturday and i would REALLY like to fix her prior to that so I don't waste that appointment.
Thoughts?
For comparison, here is a video of how it was running before the engine work. Also, it does stumble a little bit but thats because i'm running a rough tune on a haltech and theres a spot that's too rich.
[youtube]
http://www.youtube.com/watch?v=AF06tRXsTpY[/youtube]
