ok im really confused now and dont know what the problem is. just rebuilt the ca18det motor.. got new rings etc. the head we didnt touch it was fine..the motor has excellent compression. had the wrong ecu... got the jdm one and operates better now. fuel pump turns on.. fuel is getting to the block, got a new ignitor chip.. so we have spark now.. coil packs work very good. starter works perfect car acts like it wants to start just .... WONT. alternator is great also. injectors all work. maf sensor works.
when i check the ecu.. whether its pluged in or not. the car works exactly the same.. i.e. gauges all turn on.. fuel pump on. etc.. which to me is odd. and when we plug in the ecu the code off the box is 12345, 12345, 12345 over and over again. can some one please help? my email is
[email protected]
