Selleen »
https://forums.nicoclub.com/selleen-u166170.html
Sat Aug 14, 2010 12:14 pm
Hi, After the install of 444cc,z32 and stage 3 chip I got problems with my ca18det.
It got slow gasresponse(1 sec after?) and jump and "brakes" when the boost/load comes. It feels like a intercooler leak. But the thing is then i put my stage 2 chip and original MAF back it goes alittle fat but much much better, but thats cause the 444cc injectors.
I think its running very very rich, black smoke and smelling gas. I've tried to change the engine temperature sensor cause i got a faultcode on that and now my ECU shows 5 red flashes and 5 green (OK)!
The Z32 N62 maf wiring is Okay!
signal - B
ground - C
ECU ground - D
12+ - E
The signnal from the Z32 is around 1.2 - 1.3 on idle, checked to the ecu.
No boost leakage, checked many times.
What can it be? Got right signal from MAF(I think?)
The first 3 seconds when i start the engine the gasresponse is like it should be.
Have any idea what it can be??
