ca18det problem with revs. need some help.
silviaS13lover
Car: yellow llama onevia
ok i just got my ca swapped into my s13. it fires right up, but when u rev it it goes like "woo woo woo woo". etc i checked out the wiring and its all legit. i borrowed a friends maf and switched them. had a spare ignitor chip and tride that. still no change. when i unplug the maf, it still responds the same. im getting power and ground to the maf so im completly clueless. not sure what to do next. any help? thanks.
Modified by silviaS13lover at 9:03 AM 11/22/2008
mbmbmb23
Can you post a video with sound?
silviaS13lover
i cant at the moment. i just did the water pump gasket, because it started to leak. then we took of the belt and messed up the timing. i got the pump back on, i found a nice guide to fix my timing. so im going to do that when i get home from work.
articzap
Car: 2014 F150 FX4
Turbo spooling? lol
silviaS13lover
just finished my timing. im still leaking coolant from my pump, but i noticed on of the screws has a stripped tip. im going to replace it, then hopefully that solves my problem. i examined the water pump and didn't notice any cracks. as soon as i get that problem fixed, i can move on to the maf problem. it sucks im having all these problems, but im learning more about ca's. o, yes the turbo spools.
silviaS13lover
i finally got it figured out. it was a bad ground. i runs awesome.
