pulsar gtr wrote:Hi Dee,
As I mentioned, we can all sit here and jump into assumption until you do the leak down test, we can only assume things.
My suggestion, is after you do the leak down test, and I would say that your valves aren't shutting off completely, to disconnect the timing belt only which will force the valves to close then do a leak down test while the timing belt is off and see if you have any improvement.I don't believe it is a fueling problem as if it is, it shouldn't effect his compression.I rebuilt a ca18det and drove it for two days which then I did a compression test on it and it was 160psi all accross.
If your rings don't have the right gap as some one might have suggested, you should be getting some blow by oil, are you getting blow by ?
Good luck man,
RafiPULSAR GTR
Hey Rafi, there is air coming out of the exhaust side cam cover. Although it is not excessive, it appears to be somewhat normal for a fresh rebuild. There's no oil coming from this spout like you would normally find in a car with worn rings or worn cylinders. I've swapped the 272 cam back to the exhaust side and put the 264 cam back on the intake side so that I can narrow down my issues.
Like I've stated in previous posts, the plugs tell a story and there is no oil coming in the combustion chambers that is considered excessive or to my knowledge at all. All plugs look the same, all cylinder pressures were exactly the same. I was more expecting some unven cylinder pressures, but i suspect the machinists did a magnificent job at lightly honing the cylinders, the bottom end seems to be holding up pretty good at over 130miles on the engine, I even got careless and gave the thing a burst of boost to see if it would spit any oil or change oil pressure and to no avail (all was good).
I didn't do the leak down test because I forgot to pick-up the tester, so I'll put it off for tomorrow after work. All timing was on (this I didn't doubt), but I did find a small oil leak that needs my immediate attention from the plug just above the oil pump. My machinist removed it to get a deep cleaning in the engine's oil galleys and gave me bootleg custom piece to put back and now it's apparently dripping a bit of oil around, so I need to square this away ASAP. I seriously see me pulling this head, but for what remains to be told. I hope I don't, but I know it wasn't the camshafts that have the compression sitting at 90 psi. These are HKS pieces and they are not that eccentric in overlap nor lift. The adjustable cam gears are intact as I do things by the book when it come to engine mechanics.
So in short, we'll see! Thanks for chiming in as usual as you know you are a valuable member to this forum as well who's opinion has weight and bearing. And Thanks to everyone else as your opinions are welcomed and appreciated as well.
On a side note, I'm human like everyone else and am entitled to some mistakes, but when it comes to me and this engine, I exert myself to leave very little room for mistakes. If I make one, I'm man enough to say admit, correct and move on, but this is not my doing here. If this continues, this motor will have to be replaced as I've been told to do so by many go faster guys in my neck of the woods.
dee
Dee
