CA18det power steering Option and opinons.
Slideways^Jordan
Car: 1989 240sx Coupe-1991 240sx Hatch back
ok i finally got my CA running but it has HICAS power steering pump and i want to delete that shat of a PS pump its always leaking. so i would like a non HICAS pump for my CA but IDK if i can find one.
So what are my options of crossover power steering pumps i might be able to use.
Thanks for any help
Jordan
Slideways^Jordan
anyone here know
ser20det
Car: Silvia K's 88
Why not use a ps pump from a non-hicas Ca18det silvia ? I think it's the best thing to do.
Slideways^Jordan
Thats exactly what i was thinking but i need to find one if nobody is saleing one in the for sale thread you know.
ser20det
Car: Silvia K's 88
I can personnaly can get them brand new from nissan but those are surely expensive and take long to make their way to us . The bad thing is that almost part comming from japan are Special order and are not-refundable.
I working on ''something'' to get better brand new jdm part service here in Montreal. Not easy but possible !
Slideways^Jordan
ser20det wrote:I can personnaly can get them brand new from nissan but those are surely expensive and take long to make their way to us . The bad thing is that almost part comming from japan are Special order and are not-refundable.
Thanks
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
It sounds like you need to talk to local Datsun people using a CA18.
We throw away these heavy parts when doing transplants, as the Datsuns don't have power steering.
I live in Australia so I'm no help. Surely some Datsun people in the States would have one. Try in the Datsun section of NICO.
RM12577
Car: 89 Nissan 240SX with CA18DET
94 Nissan vert in need of work
just remove the fins from one side and block off the outlet on that side and the hicas model will work fine. mine works great like that with no problem
Woods Crasher
I'm Using a 91-94 KA24DE p/s pump...
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
i use good old fashioned muscle... the fact that my front wheels are 4inches wide also helps with the ease of turning without my PS =)
mbmbmb23
RM12577 wrote:just remove the fins from one side and block off the outlet on that side and the hicas model will work fine. mine works great like that with no problem
Yeah, just block off the port for the rear line. The pressure rating for the HICAS unit is higher than the non HICAS but that shouldnt be an issue.
-m
float_6969
If you just cap it off, it'll still leak. You've got to take it apart and remove the impeller.
Slideways^Jordan
ok Thanks for the info guys.
Slideways^Jordan
Woods Crasher wrote:I'm Using a 91-94 KA24DE p/s pump...
what all did you have to do to use tha Dual cam KA pump on the CA
Bwana
Car: Denali
Slideways^Jordan wrote:ok Thanks for the info guys.
I use a DOHC KA pump on my RB... Just some mix and match stock bracket voodoo. Unless someone has specific info I'd suggest picking up a pump with brackets and messing with 'em till you find something that works.
float_6969 wrote:If you just cap it off, it'll still leak. You've got to take it apart and remove the impeller.
And removing the impeller blades is a piece of cake, 15 min job max.
Slideways^Jordan
Sweet im going try to revome the impeller blade, but for now i just took off the powersteering pump pully.
koukicody
Car: 93 Mazda Miata
http://neotechimports.com/top.html
e-mail him. he might be able to help you with getting just the pump....
Slideways^Jordan
koukicody wrote:http://neotechimports.com/top.html
Thanks
Slideways^Jordan
Well i just fisihed removeing the Impeller blade son the hicas side and it works perfectly now. Thanks for all the help guys i appreciate it alot.
Jordan
float_6969
Glad to help.
I wish somebody would do a write up on that.
I'd put in in the stickies and we'd get you a custom title under your SN.
Slideways^Jordan
float_6969 wrote:Glad to help.
Dang i was gonna take pics and thought about doing the write up
after doing that PS pump really it was so simple. Didnt even take that long.
Bwana
Car: Denali
Removing the impeller blades on a hicas pump is seriously one of the easiest things evar...
91rs13
Car: Nismo 350Z
Datsun 510
Dodge Ram 1500
I had a Hicas pump and removed the rear blades etc and it worked fine. When that pump crapped out I replaced the pump with a non hicas pump. But to do that --you need a non hicas bracket. The pump was off an S12 I believe.
RM12577
there are some rb forums that i was on that gave me the impeller blade idea and i made myself a brass fitting to block off the second side and made a stainless adapter for the power steering reservoir feed line, they sell adapters at o'reilys as well, would make a good sticky though just dont have pics from when i did mine... easy to explain without pics though
