CA18DET OS Giken Twin Disc Clutch For Sale
OverBoosted180
Car: 89 S13 CA18
float_6969
You're timing is terrible. I have a bad feeling I'm going to surpass what my SPEC Stage 3+ is going to be able to hanlde, but right now, the funds aren't there to be able to afford this. G/L w/the sale!
OverBoosted180
Car: 89 S13 CA18
float_6969 wrote:You're timing is terrible. I have a bad feeling I'm going to surpass what my SPEC Stage 3+ is going to be able to hanlde, but right now, the funds aren't there to be able to afford this. G/L w/the sale!
:gotme LOL Damn, Sorry Float! This would be great for your setup! But thanx anyway!
float_6969
So if this wasn't enough clutch for your setup, what are you replacing it with?
OverBoosted180
Car: 89 S13 CA18
float_6969 wrote:So if this wasn't enough clutch for your setup, what are you replacing it with?
Having stock transmission issues, so i've decided to go a different route for more power.
float_6969
I always wondered about what the limit of the stock transmission was. The guys in europe say it's 300whp, but I think that's in a drag racing environment. About what power level did you think you started to have issues?
tommey
Car: S13 ca18det
"us guys in europe" say about 400+ whp wich seem to be "agreed" by most people in norway and sweden.
A little weird to ask the guys using normal "chip setups" to change gearbox in the same process because they are going to hit 450+ whp.
float_6969
ah, ok. That sounds like a more resonable power level. What part of the stock trans fails?
tommey
Car: S13 ca18det
Usually third gear.
float_6969
Hmm, goes the gear fail, or is the issue related to the housing flexing?
tommey
Car: S13 ca18det
The gear fail, but i dont know if thats a result of something flexing.
I would like to know what setup OverBoosted180 goes with now.
Im a fan of tilton + z32 for a streetcar.
float_6969
tommey wrote:Im a fan of tilton + z32 for a streetcar.
tommey
Car: S13 ca18det
Correction: High powered steetcar.
If you use the tilton thick discs they are pretty driveable as oposed to the thin discs.
They are also really cheap but of course no point if you are going for 400hp.
float_6969
Ahh. Man, all this talk of 400hp creating issues in the transmission is making me re-think my power goals. Maybe I won't crank this T04E all the way up and see what it does.
tommey
Car: S13 ca18det
You should see what it can do!
If the box should break then it breaks.
No big deal.
And of course, it comes down to how you treat it.
OverBoosted180
Car: 89 S13 CA18
Keep in mind guys, the transmission hasn't completely taken a crap, it was whining pretty loud and i didn't want to find out what and how it would break. LOL I need this clutch gone!! No need for it.
float_6969
tommey wrote:You should see what it can do!
No big deal.
That's true, and the S14 is a toy, so it's not like I'm out anything if it fails. If it's just 3rd gear, I wonder if cryo/shot peeen/etc treatment would resolve the issue? Anybody tried this?
tommey
Car: S13 ca18det
I think someone in the UK did it to an entire box
not sure of the results or even if they really did it
A brand new z32 box is pretty cheap so I don't know if it's worth the hassle.
float_6969
Are all of the Z32 transmissions the same, or just the turbo?
tommey
Car: S13 ca18det
If I remember correctly there are some bellhousing differences between the NA and the turbo. some came with ports for cooling.
internally they should be the same but the 98+ Japan boxes has redesigned gears and better syncros.
That's the one z1motorsports.com sells.
float_6969
Good to know.
tommey
Car: S13 ca18det
Btw OverBoosted180, you could probably sell it as an sr20 and rb25 clutch also.
Depending on flywheel design.
OverBoosted180
Car: 89 S13 CA18
tommey wrote:Btw OverBoosted180, you could probably sell it as an sr20 and rb25 clutch also.
Cool, Thanks! :dblthumb:
