ca18det or ca18de???
tranx
Car: 200sx
hey guys im new to this so here goes
i recently picked up a 180sx at the auctions with a CA in it. the thing is,,,,,the information plate located in the engine bay says that its a CA18DET,,,,,but! the bloody engine in it now has no turbo??? its got the stock intercooler but no piping no turbo.
im thinking the previous owner might have taken out the turbo and the manifold and replaced it with a ca18de manifold, so the turbo engine is running with no turbo???? (i could be wrong) lol.
the other thing could be that the previous owner took out the ca18det engine and replaced it with a CA18DE engine without changing the information.
is there anyway to tell if its a CA18DET or a CA18DE??????? help please!!!!!!
themadscientist
what color are the plastic parts of the injectors? Red=260 and CA18DEWhite=370 and CA18DETIf you can get a good angle down the spark plug hole to shine a light and peek you should be able to see if the pistons are domed with the piston at the bottom of the stroke. Domed = CA18DEDished = CA18DET
tranx
Car: 200sx
i will check that out, is there any other way? ^^
themadscientist
Those are two of the ways that don't require you to tear the motor open. If you would rather do that, piston oilers screwed into the block aiming up at the bottom of the pistons are for sure turbo gear.
You could look for a big *** aluminum dropping resistor near the air filter for the low impedance turbo injectors. Also there could be a boost control solenoid on the passenger side strut tower.You could look for signs of the turbo's oiling system as well, namely a conspicuously new pipe plug screwed in the passenger side of the block around the second cylinder and the drainpipe sticking out of the oil pan which would need to be capped.
boost_boy
Just check the compression, it will instantly tell you what slugs are in those bores and you can go from there. In any case, a conversion can be done if it's a DE and gives you a chance to refreshen the internals for peace of mind.
Dee
themadscientist
With all the greasy packrats here you could get any part you need.
tranx
Car: 200sx
speaking of compression, i did a compression test the other day here are the results
cyl 1. 138
cyl 2. 130
cyl3.125
cyl 4. 130
(ohh by the way im from australia lol)
Modified by tranx at 5:44 AM 10/7/2007
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
well its either a shot to hell de..... more likely it is a det with those numbers.
tranx
Car: 200sx
could be lol....i cheked the injectors and they are red, but thi guy in another forum said the other way around. white=turbs and red = non lol?????
themadscientist
themadscientist wrote: Red=260 and CA18DEWhite=370 and CA18DET
tranx wrote:could be lol....i cheked the injectors and they are red, but thi guy in another forum said the other way around. white=turbs and red = non lol?????
We have a consensus
tranx
Car: 200sx
ohh my bad lolz thanks guyz
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Either way it needs to be pulled and freshened up. You will know for sure what it is then. Did the rwd ca18de's come with oil squirters or was that a turbo only thing? I know none of the fwd de's came with them, but this is the US and we continually get the shaft from jap car manufacturers.
Liquid_Neon
squirters are over rated. Just run a lil richer and/or get forged pistons!
9:1 or higher.... its the way to be!
