wookiet wrote:progman apparently you have no idea what your saying. I have asked around, and even know for a FACT the car will shut down if your MAF detects no air filter.. Trevr the chip I put in seemed to be a performance chip I looked it up and it says with the chip to only run 91+ fuel. I have a feeling the guy who had it before had done something to ecu though so if worse comes to worse and it still doesn't idle I'll replace the ecu and let you know.
YOU DO NOT HAVE TO HAVE A MAF for the car to run, start, or do anything......
it will flip the ECU into limp mode and will idle and wont rev passed 2k so that in the event something bad happened you could still limp the car to somewhere safe or home. Ive done it more than once due to blown couplers...........
he modified the ECU likely, meaning you need to install the burned chip to run as that is the heart of the ECU. its like taking the harddrive out of your CPU and asking it to do something.
it sounds like a broken record, but the coolant temp sensor is like one of the most important components next to the CAS for this motor. its even more important than the maf.
I have to say I agree w/ program, you are being a bit of an idiot and all of this info has been covered before. running a motor KNOWING it doesnt have all of the components assenine.
take some pictures of the ECU(w/ the covers removed so someone can tell you of the ECU is still stock or if it requires a chip installed)
tell us what it DOES DO when you try to start it(once you finally have all the parts).
take advantage of all the info here.......... there is so much to be had, it is rediculous. hell you have an entire manual at your figure tips w/ ALL of the info on this motor........
PS please DO NOT push start these motors.
