Do you have an injector resistor? I'm in Georgia at the moment, but if I were closer, I'd solve that problem for you. And if you harness is screwed-up (hoperfully it is not), worst case scenario would be dead ecu. But I doubt if that's your dilemma. Take your time and go over everything again to make sure it's done correctly.Zzca18deTzZ wrote:i added a reply to another post but was advised to start a new thread. sorry about all that admins. anyway... here is my issue. my car car is getting spark. the fuel pump is priming and is sending fuel through the fuel lines. i dont know about the fuel pressure if there isnt enough or if there is just a bad wiring prob. somewhere but the injectors are not sending fuel or not sending enough fuel. when i try to start the car it will crank but never turn over. i did spray starter fluid in the intake which does cause the car to turn over... for about 3 seconds. any input? i think its a wiring issue cause the car has had a known issue with that... thats why im looking for a new harness. i guess it could be furl pressure too. anyway, any input is needed! thanks for your help guys
-Sean
im almost positive i did that already. but i will try it again. ive checked A LOT of stuff that has to do with the mechanical part of the motor. and a good bit with the electrical thats why its so frustrating! im almost positive its something in the wiring harness. but if anyone else has some ideas let me know.50-50 wrote:getting spark = ecu, ca sensor workinggetting fuel thru lines = pump working
ok then it should at least try to start. maybe the fuel lines going to the motor are mixed up, u know, feed line on the regulator instead of the return line being there.
just curious but did you ever find out what the reading is suppose to be. i think im gonna try and check the sensor tomarrow. also... if i decide to get a new one is that one of the parts that cooresponds b/y the ca18de and ca18det? (can i go get it from the local parts store) if not where do i need to order it from.thankscandyredtd wrote:1) Check your temp sensor, not sure of the value of hand but it is in the work shop manual and should be a certain amount on the multimeter if this sensor is not right it will not fire no matter what.
Resoultion to this is simple replace your temp sensor
True. well it didnt make a difference anyway. i tried a bunch of stuff today and i got no where. re-checked the fuel lines. put new gas in it just in case the gas in it was old. made sure the injector plugs were in the right order. checked the spark plugs. i would really like to replace the temp. sensor but no one has answered me about the temp. sensor. i need to know if the temp sensor in the ca18de is the same as the ca18det. i would REALLY like to get this thing on the road soon otherwise a part out might be in order. the more and more i check stuff the more and more i think its the ECU.anyway if you have any more ideas let me know.float_6969 wrote:I'm at work, and so I don't have a FSM to check, but how would they be injector grounds? The injectors are grounded through the ECU. That's how they are turned on and off.
It goes like this;battery->ignition switch->resistor pack->injector->ecu->ground
