CA18DET NOT FIRING on first cylinder!! helpp!please.
s13timmy
Car: 92 hatch
my ca wont fire on the first cylinder. ive swapped the injectors around and the coil packs and mixed them all around. ive heard its comon for a ca not to fire on the first cylinder. its got a brand new head gasket. and i cleaned tthe crap out of the intake mani, and the butterflys and i cleaned the valves and valve seats with grinding compund. anybody ever have this or heard of this??
s13timmy
Car: 92 hatch
when i get home im gunan give the coil pakcs an ohms test. and see if its a short in the coil wiring mabey? and im gunan check to see if the fule rais plugged with seddiment ro something.
Car: 240sx
so you swapped you injectors and coils around....is it still the first cylinder missing? is there spark or fuel? did you check compression? is there power going into the injectors?
s13timmy
Car: 92 hatch
right. i switched the coilpacks around and im getting spark. but idk if its enough mabey? but i havent checked for power to the injectors. but i do know that they all do work.
