trevr »
https://forums.nicoclub.com/trevr-u54144.html
Tue Jul 03, 2007 11:02 am
Car starts, but still won't rev over 2k rpm. I have narrowed it down cylinder #1 not firing.
Anyone else know what could be causing this.
I have had my injectors professionally cleaned and verified working. Installed new spark plugs on all four, swapped around coil packs, and tried three different injector resistors. All terminals to the coil packs and injectors have proper voltage, and ohms. It all leads back to cylinder #1, I can unplug either the injector or the coil pack and it will continue running the same way. I also have a stainless steal header on which all runners have darkened except the runner to cylinder #1, which is still shinny.
The casing on the back of my igniter is damaged, so I recently purchased a replacement, that will be here next week.
I'm also thinking about replacing the ECU, but before I do that does anyone have any experience with this setback? Any help is greatly appreciated!
