Hi Quantum! I would like to be the first to welcome you and your first post here on NICO. I'm going to help you as best I can, so here we go. Things to check for: Vacuum leaks (check everywhere) and re-check wastegate function. Since you said your vacuum gauge is not showing boost, it tells me that you're leaking air somewhere. Take your time and go over your car's plumbing well and I'm very sure you'll find the culprit.Quantum wrote:Hey guys, i've been looking around on this forum for some time,as i was doing some research on the ca18, anyhow, i now have a 1988 nissan sentra with a ca18det engine in it, Just yesturday, i noticed that the car was not boosting it barely comes off vaccum but doesn't reach to 0 lbs or over.. the wastegate actuator does not respond either, i removed it an pressure tested it,and it's fine..the diaphragm is ok... what do you guys think?, so far i've checked for boost leaks where the ic pipes join etc..etc.. and havent found any... although i think i might double check it, but what else could be the problem.
Specs: Garrett T03( .48 back, .60 front), 444cc injectors, 2 1/2" exhaust, Fmic , 2 1/4" IC piping.
Looking forward to hearing your take on this problem, thanks in advanced,,
Not a problem. What gearbox are you using? My jamaican brethren here have respect for it. If you ever get a chance, post some pics of your car. It doesn't have to be show quality, but we'd love to see it as there are not too many CA powered sentras around. And lastly, I got a teaser for you. I have a 1991 B13 sentra with a CA18DET in it. The engine is still stock, but it's supporting cast is not and it will be coming to someone's track and some video footage soon. So far, it's the only one I know of anywhere in the U.S.Quantum wrote:Thanx man, i'll jump on it first thing tomorrow morning. I just bought this car and i'm restoring it to its former glory as the previous owner didn't have respect for the ca18 engine or the Nissan brand, so i'm just straightening out some stuff on the car, changing seals etc..etc.. so that it can be a head turner, as ppl in jamaica are not aware of the potential of a ca18 engine..and i would like to show them that, but i'm taking it one day at a time until i reach my goal, Looking forward to learn more than i've already learnt on this forum. Thanx again.
